transmission service instructions please
110,000 MILES • 5.4L • V8
ELMER CORWIN
I have the truck listed above with a 5.4 Triton engine. I have a lack of power when accelerating it almost seems like a transmission slipping when accelerating also, probable causes.
Dec 18, 2020 at 10:16 PM
  • 55,542 POSTS
We need to know which is happening, we can do so by checking the condition of the transmission fluid, it could be burnt which we should do a service.
Next we should run the codes.
This guide can help as well:
https://www.2carpros.com/articles/engine-has-low-power-output
Mar 23, 2021 at 5:19 AM
ELMER CORWIN
Doing a diagnostic check lean codes came up on bank 1.
  • 55,542 POSTS
That wont cause the transmission issue. we will need to get a sample of the fluid to see if it smells burnt please let me know. if it needs a transmission rebuild this video will show you the steps to remove it. (similar job)
https://youtu.be/3vJAojsrfuU
