Okay. Replaced MAP, MAF, crank, cam, IAC, TPS, PCM ,relays fuel pump,injectors,fuel pump regulator,timing belt,spark plugs,ignition coil packs,air filter and entire air intake housing assembly. Rebuilt throttle body. Checked for correct voltage and resistances on every circuit. Timing is TDC compression stroke, have awesome compression. Temperature and knock sensors great, oh yeah, even installed brand new O2 up and down stream sensors just for the fun of it. Still cranks, no start. Anyone?
Oct 17, 2019 at 3:54 AM
