Trunk wont close all the way down.
95,000 MILES • V6 • FWD • AUTOMATIC
BONNIE LAWSON
I don't know if someone slammed the lid and caused it. It goes down to the catch but wont go any further. I've been told there is a latch that needs to be opened. I cant find it and I have gone through the Owners manual with no luck. I really appreciate any help you can give me.
Oct 30, 2015 at 12:23 PM
CARADIODOC
  • 34,415 POSTS
If the trunk is latching and can't be pulled open unless you turn the key to release it, the latch is working properly and nothing needs to be opened. Once latched, a failure of the pull-down mechanism to pull the lid down the last inch is usually due to a problem with the built-in switch, or a blown fuse. The switch is what tells the mechanism the trunk has been latched and it's time to pull it down.
With the latch released and the lid up, out of the way, you can use a screwdriver to mimic the striker on the bottom of the lid to trick the mechanism into latching and puling down. You can usually see the switch or at least cause it to activate. If you're lucky enough to see some minor sparking in the latch, that suggests the switch is trying to do its thing but has corroded contacts that aren't turning on properly. If there is no sparking, clicking, groaning, buzzing, or any other sign of life, a blown fuse is a better suspect.
Oct 30, 2015 at 1:23 PM
