The key that came with the car does not unlock the trunk?
1969 CADILLAC DEVILLE
73,500 MILES • 7.7L • V8 • 2WD • AUTOMATIC
CHEVY__88
  • 104 POSTS
So, the key that came with the car does not unlock the trunk. There is no button in the glove box. I live out in the county and no one services. I've soaked it with wd-40, I've taken a rubber mallet and lightly banged on the lock with the key in it, and all around the trunk. Could I just drill the lock and pop it with a screwdriver? Tips or videos would be appreciated.
May 7, 2024 at 8:41 AM
  • 110,244 POSTS
Yes, you could drill the tumbler out and turn it with a screwdriver and then replace the lock assembly.
On the other hand, you may be able to access the trunk if you remove the back portion of the rear seat. Have you tried that already?
May 7, 2024 at 12:31 PM
CHEVY__88
  • 104 POSTS
Yeah, I've removed the back seat, but no crawl space and the spare tire is mounted right in the middle, so I can't get a rod through to manually unlock it.
May 7, 2024 at 1:17 PM
  • 110,244 POSTS
Other than having a locksmith make you a new key, you will need to drill it out to open the trunk. If you have a chance, let me know how things work out for you.
May 8, 2024 at 11:32 AM
CHEVY__88
  • 104 POSTS
Yeah, I drilled it out which was fast and easy enough. Now trying to get to the locking mechanism below the drilled-out key was a pain and it took a good minute to unlock with a screwdriver.
May 8, 2024 at 11:38 AM
CHEVY__88
  • 104 POSTS
No hidden gems inside the trunk besides the jack system and original white wall donut tire.
May 8, 2024 at 11:39 AM
  • 110,244 POSTS
Thanks for the update. I'm glad you got it open.
Please feel free to come back anytime in the future if you have questions or need help with something.
May 8, 2024 at 11:46 AM
