The stabilizing shock blew a gasket and fluid empty.
What part number and how to replace/fix?
May 12, 2018 at 10:30 AM
PATENTED_REPAIR_PRO
✓Experienced Mechanic
I do not have any instructions, but I would assume once the trunk is fully open place a stick back there holding the trunk open while you remove the lift support. They cost anywhere from $8.00 to $16.00 each and Rockauto has quite a few to choose from as well as most likely plenty of other auto-parts stores, https://bit.ly/2Kk2BQK
