Trunk Brake lights, Spoiler Brake Lights not working
1999 SUBARU LEGACY
178,000 MILES • 2.0L • 4 CYL • TURBO • 4WD • MANUAL
RIZZYNZ
Hi Team,
I have a Subaru Legacy B4 1999 Sedan (similar to the picture attached). The brake lights on the Trunk do not work along with the Spoiler Brake Light. I have replaced the bulbs with new set and still that does not work. I swapped the trunk lights with the outer body lights just to test if the bulbs could be faulty but on the outer lights it works fine which ruled out the bulbs are ok.
I have checked all the fuses using a multimeter for continuity and they all seem to be fine. The fuses checked were the set in the drivers side below the ignition (approx. knee height). Also the set in the engine. (photo attached). All these fuses seem to be ok.
What can I do next before taking this into an auto electrician?
Kind Regards
Rizwan
Jun 27, 2015 at 8:22 PM
WRENCHTECH
  • 20,761 POSTS
This depends on what your electrical knowledge ad ability is. The first step is going to be to test for power coming into the brake light switch and back out when the brake is applied.
Jun 27, 2015 at 9:26 PM
RIZZYNZ
Thank you for such a quick response...
This site is amazing
Could you kindly give me all the steps to take in order for me to find the root cause is. So bulbs checked, and fuses checked.. as per your suggestion above, now I will check for the power, what's next if the power id ok.. I had a look at the other related questions from other clients and they are all similar... sorry its 1204am here in New Zealand so I will have to do this in the next 8 hours. lol
Thanks
Jun 27, 2015 at 10:06 PM
RIZZYNZ
Sorry one last this there no power on the bulbs area nor by the spoiler but no fuses have blown. visual check done and just to be safe multimeter check done individually on all fuses.. ]
cheers
Jun 27, 2015 at 10:09 PM
WRENCHTECH
  • 20,761 POSTS
Since either you have posted the wrong engine size or that vehicle combination just isn't sold in the US, I can't even supply you with a wiring diagram. I can't tell you how to troubleshoot a wiring circuit either. If you don't have some electrical knowledge and equipment, you are going to have rely on a local repair shop.
Jun 27, 2015 at 10:32 PM
RIZZYNZ
That's fine mate. ..
Sincerely thank u for your time.
Jun 28, 2015 at 4:38 AM
