Truck will not start when hot
148,568 MILES • 3.9L • 6 CYL • 4WD • AUTOMATIC
BILLC324
After driving truck when it is shut off for ten or twenty minutes it cranks but will not start until it cools off. while it is running it is perfect.
Jun 21, 2017 at 1:37 PM
CARADIODOC
  • 34,414 POSTS
That is the classic symptom of a failing crankshaft position sensor or camshaft position sensor. They often fail by becoming heat-sensitive, then they work again after cooling down for about an hour. Have you read the diagnostic fault codes? Do you know how to do that yourself?
Jun 21, 2017 at 2:38 PM
BILLC324
Thank you so much. I will put on my vehicle code scanner tomorrow and thank you so much. Bill Curry
Jun 21, 2017 at 2:47 PM
  • 55,746 POSTS
Cheers, Ken
Jun 24, 2017 at 4:41 AM
