Truck won't start, just clicks and backfires
200,000 MILES • 2.2L • 4 CYL • AUTOMATIC
FLIPP985
Just cut off on interstate after stopping for gas got back on interstate, hit about 70mph for aprox 3miles went to go around a 18wheeler and when I went to accelerate it started dropping speed and cut off. Popped the hood a lot of smoke was coming from by the spark plugs down by engine. Was so much smoke I think it's possible some wires were sizzling. Smoke wasn't coming from my radiator so I don't think it was over heated. My gauges inside the truck never indicated it was over heating. Now it clicks and backfires when try to start. Had a couple people try to look at it and said the motor still turns, my fuses were good and they don't believe it was anything to do with starter. What could it possibly be? No scan tool to check for code.
Oct 1, 2014 at 6:22 AM
HMAC300
  • 48,601 POSTS
you probably blew a head gasket or broke a timing chain or dist gear got worn off. especially with the miles on it.
Oct 1, 2014 at 8:44 AM
