Truck will not start after replacing relay
188,000 MILES • 4.7L • V8 • 4WD • AUTOMATIC
DAVIDRAMBO2
  • 10 POSTS
I was told I had a bad A/C condenser fan relay. so I bought one from AutoZone and replaced the bad one, but now my truck just cranks over and won’t start. I tried putting the old relay back in but no luck. any help is appreciated.
Aug 21, 2019 at 8:06 AM
Good evening,
Check all your fuses with a test light for power on both sides. Do not do a visual test, do the power test.
Chances are you either have a bad relay or you put it in with the wrong terminal alignment and it shorted and blew a fuse.
Aug 21, 2019 at 8:49 AM
DAVIDRAMBO2
  • 10 POSTS
I have tested all relays with a light, it couldn’t have been put in the wrong way, the pins were positioned to only fit one way.
Aug 21, 2019 at 8:53 AM
Did you test the fuses as I suggested? I asked for the fuses, not the relays.
Aug 21, 2019 at 8:58 AM
DAVIDRAMBO2
  • 10 POSTS
Yes, sorry meant to type fuses and relays.
Aug 21, 2019 at 10:01 AM
What was the voltage at the fuses?
Aug 21, 2019 at 7:14 PM
DAVIDRAMBO2
  • 10 POSTS
I tested them with a light like you said to. I have an ammeter but I am not sure how to use it to test the fuses.
Aug 22, 2019 at 7:52 AM
Are these the 2 fuses you checked with a test light?
Aug 22, 2019 at 8:01 AM
DAVIDRAMBO2
  • 10 POSTS
Yes, both of them light up.
Aug 22, 2019 at 8:13 AM
Can you check for spark? Crank the engine and see if the tachometer moves.
Do you hear the fuel pump run when you turn on the key?
Aug 22, 2019 at 8:18 AM
DAVIDRAMBO2
  • 10 POSTS
Tachometer moves when I turn the key. I cannot hear the fuel pump priming.
Aug 22, 2019 at 8:21 AM
Okay, the crank sensor is working.
If you have some starter fluid, spray it into the air filter and see if it starts and stalls.
Aug 22, 2019 at 8:23 AM
DAVIDRAMBO2
  • 10 POSTS
Just to confirm, spray the fluid onto the filter itself?
Aug 22, 2019 at 8:30 AM
Just squirt some fluid into the air filter.
Aug 22, 2019 at 8:37 AM
DAVIDRAMBO2
  • 10 POSTS
Engine didn’t attempt to start, just cranking.
Aug 22, 2019 at 8:39 AM
Can you check for any codes? Do you have something that can read codes?
Aug 22, 2019 at 8:40 AM
DAVIDRAMBO2
  • 10 POSTS
I checked with my obd2 scanner, but it’s not throwing any codes.
Aug 22, 2019 at 8:45 AM
DAVIDRAMBO2
  • 10 POSTS
this has me stumped. thanks for continuing to reply quickly and consistently.
Aug 22, 2019 at 8:46 AM
No worries.
Can you check for voltage to the coils? Do you have a voltmeter to check this?
I attached a diagram for you. check the highlighted wires for power with the key on.
Aug 22, 2019 at 8:51 AM
