Truck will not start
220,000 MILES • 5.7L • V8 • 2WD • AUTOMATIC
KCLAYTON
Vehicle has been running solid for years. Drive it yesterday and parked it just like I always do. Went to start it back up a little while later and it won’t turn over and makes a high pitched tone. Checked all the fuses and cleaned the terminals on my less than a year old battery. Still won’t start.
Jul 13, 2021 at 4:34 AM
SQM
  • 6,383 POSTS
Can you possibly upload a video/audio of the noise you are hearing?
Many time the starter can make a high pitch noise if its not engaging.
Here is a basic engine no start guide might be helpful:
https://youtu.be/dCjmRL3p4Cs
Jul 13, 2021 at 7:08 AM
KCLAYTON
Turns out the noise is my horn.
Jul 13, 2021 at 7:14 AM
SQM
  • 6,383 POSTS
Does the starter 'clicks' or makes any noise when you turn the key?
https://www.2carpros.com/articles/how-a-starter-and-solenoid-works
If the starter makes a noise then it could be a bad solenoid.
Jul 13, 2021 at 7:16 AM
KCLAYTON
No. When I turn the key the noise that it makes is coming from the horn.
Jul 13, 2021 at 7:17 AM
SQM
  • 6,383 POSTS
If you try to jump start the truck does the horn still goes off? Sometimes low voltage could make the electrical components act strangely. Let me know please.
Jul 16, 2021 at 2:44 AM
KCLAYTON
We’ve narrowed it down to a dead short. Still haven’t found it. Removed the horn relay and the horn fuse and the horn would still make noise. It’s back feeding through the ground somehow.
Jul 16, 2021 at 3:08 AM
SQM
  • 6,383 POSTS
I have attached the wiring diagrams for the horn as well as few other diagnostics tips.
Any questions please let me know.
Thanks.
Jul 16, 2021 at 3:20 AM
KCLAYTON
The horn isn’t the problem. it’s a by product of the problem.
Jul 16, 2021 at 3:28 AM
