Will not start unless it is jump started?
1998 CHEVROLET S-10
151,000 MILES • 2.2L • 4 CYL • 2WD • MANUAL
BRENDA MCGRAW
  • 16 POSTS
I had the starter and solenoid checked and they are both good. Replaced the battery because of a dead cell in it and still cannot start without a jump. what do I look for next?
Apr 28, 2023 at 1:40 AM
  • 110,194 POSTS
If you can jump-start it, check to make sure the battery terminals are clean and tight. When you place the jumper on it, there is a chance it is tightening things enough to make a good contact.
When you connect the jumper cables, there is still only 12 volts available, so something you are doing is creating a better connection.
Let me know. Also, let me know if you hear anything without the jumpers. For example, do you hear a click or anything?
Take a look at this link:
Also, let me know if this happens every time you need to start the vehicle.
joe
Apr 29, 2023 at 12:08 AM
