Engine cranks but does not start?
79,000 MILES • 2.9L • 6 CYL • 4WD • AUTOMATIC
KYKYJELLY88
It will crank over but won't fire up.
Jun 5, 2023 at 4:30 AM
  • 110,248 POSTS
In most cases, a crank no start condition is caused by either a loss of ignition spark or a fuel-related issue.
Here is what I need you to do. See if the engine will start using starting fluid. If it does and then stalls, we know it's a fuel-related issue. If there is no change, then I need you to check for spark at the plugs.
https://www.2carpros.com/articles/how-to-check-for-ignition-spark
Let me know what you find.
Jun 5, 2023 at 1:42 PM
