Transmission will only shift into neutral
163,366 MILES • 4.3L • V6 • 4WD • AUTOMATIC
ROBERT HICKS4
My truck will shift into neutral but when shifted into neutral wont shift to anything else. We have changed the shifter linkage.
Aug 29, 2021 at 10:28 AM
  • 110,248 POSTS
I need to better understand. Are you able to shift to reverse? If you shift directly to drive, can you do it? Is the problem with gear selection or a possible transmission issue?
I attached directions below for the removal and replacement of the shift cable. Take a look through them to make sure nothing was missed or done incorrectly.
See pics below. Also, let me know if this is a floor or column shift.
Aug 30, 2021 at 12:04 PM
