Truck will not move when on the ground
1985 CHEVROLET TRUCK
150,000 MILES • 5.0L • V8 • 2WD • AUTOMATIC
ANDREW MOTE
If i jack up the rear of the truck the tires spin, but now that it is on the ground again it will not move.
Jun 14, 2017 at 5:35 AM
HMAC300
  • 48,601 POSTS
check fluid if dark brown or black transmission is time for a rebuild. if low will do the same. even if fluid is red it still may be time due to age and or clutch pak wear or seals hard.
Jun 14, 2017 at 9:17 AM
