Soon as I release the clutch pedal it shuts off?
250,000 MILES • 6.0L • V8 • 4WD • MANUAL
VILLASATX
I can start it fine but as soon as I release the clutch pedal it shuts off. Does not matter in gear or not it shuts off, I don't even try to move truck at all.
Oct 12, 2022 at 6:16 AM
  • 110,248 POSTS
This is an interesting one. When you start it and before releasing the clutch, does the engine run properly? Can you rev the engine? If you rev the engine, can you make it move at all?
Also, is the check engine light staying on when it's running?
Oct 12, 2022 at 1:05 PM
VILLASATX
No engine light.
Yes, I can start it and rev the motor all day long but soon as I release the pedal it sounds like it's in gear but does not feel like it in any way. Wheels don't even try to move. But after it stalled, I got under truck disconnected drive shaft to see if it would stay running and no difference. After it stalled I went underneath and was able to move output shaft, so I don't think it's locked up in anyway.
Thank you for your response.
Oct 12, 2022 at 3:22 PM
VILLASATX
Is this in any way possible to be caused by a bad flywheel that is not connecting properly?
Oct 12, 2022 at 3:27 PM
