truck wont go more than 20mph
148 MILES • 4.6L • V8 • 4WD • AUTOMATIC
BAILEEJORDYN
Truck will only go about 20mph. My brother then installed a fuel filter as per auto zone. Nowproblem is wayyyy worse!!! Goes 20 then down to 5-10 mph with the RPM jumping all over the place. Ran better before filter was put in! Was told before when it was stalling out I needed a MAFS sensor ?? Could this be the problem? Obviously the filter wasn't bad? And a pain to get to I might add!!!! I'm a single girl and really need help as my brother is not a mechanic... Please ... ANY IDEAS WOULD BE APPRECIATED!!!!
Jan 11, 2014 at 7:20 PM
SATURNTECH9
  • 30,868 POSTS
Do you have any codes in the computer?have you checked yet?
Jan 12, 2014 at 12:12 AM
DBOSSEJR
Does it smoke? Misfire? Stall out? or just makes a lot of noise and is slow?
Jun 14, 2014 at 1:06 AM
