Truck will not crank
250,000 MILES • 4.3L • V6 • 2WD • AUTOMATIC
TABATHA KNOX
I cranked it up Tuesday morning I stopped at the store it was idling fine but it shut off and never cranked again. Can you help?
Jul 24, 2020 at 10:17 AM
  • 110,251 POSTS
When you say it won't crank, do you mean the starter isn't engaging and turning the engine so it can start or the starter is working, but the engine won't start?
Here is a link that discusses the most common causes of a crank no start:
Here is one that explains how to check a starter.
If you let me know exactly what is happening, I would be happy to guide you.
Jul 24, 2020 at 10:42 AM
