Engine still will not crank after replacing fuel pump
2,000 MILES • 3.0L • V6 • 2WD • AUTOMATIC
DIDEE813
  • 5 POSTS
Put in new fuel pump but still will not crank. will crank if you spray starting fluid.
Truck listed above is a 1992 with 20,000 miles.
Jul 29, 2020 at 4:40 AM
AL514
  • 5,691 POSTS
Hello, is this a Highlander 3.0L? and can you give us the VIN number please so we can look up the correct vehicle?
Jul 29, 2020 at 5:02 AM
DIDEE813
  • 5 POSTS
this is a 1992 Toyota pickup 6 cylinder 3.0 VIN number JT4VN93D5N5033354.
Jul 29, 2020 at 5:10 AM
AL514
  • 5,691 POSTS
okay, have you done a fuel pressure test? i'm going to assume you have no fuel pressure at this point since you just put a new pump in, but I would do a pressure test to start with. Here are the specs for pressure. If no pressure then the pump needs to be checked for power. You may have a bad fuel pump relay, Toyota calls it a "Circuit opening relay".
Jul 29, 2020 at 5:27 AM
DIDEE813
  • 5 POSTS
fuel is coming to the motor but is not going into the motor. the fuel pump is working.
Jul 29, 2020 at 5:29 AM
AL514
  • 5,691 POSTS
In this picture, it shows what terminals you can jump to activate the fuel pump, this can aid in checking for pressure. It also bypasses the Circuit Opening Relay, so you can rule that out as a problem. Power comes from the EFI relay next. Okay, so you're saying you have no injector pulse, this can be caused by a number of things. Such as no signal from from the pick up in the distributor, a wiring issue, a bad ECM. Lets see if you're getting any activity from the Injectors first.
https://www.2carpros.com/articles/how-to-test-a-fuel-injector
Are you missing spark too? And has this truck been sitting for along time? Does it really only have 2,000 miles on it? If that's the case, your fuel injectors may be stuck closed from sitting for so long. I have seen that happen.
Jul 29, 2020 at 5:30 AM
DIDEE813
  • 5 POSTS
no, this truck has 200 thousand miles.
Jul 29, 2020 at 6:19 AM
AL514
  • 5,691 POSTS
okay, you're going to have to check an injector for power and make sure the ECM is grounding the opposite wire. You can do this with a test light, unplug an injector and one wire should be battery voltage (around 12 volts) and then hook the test light to battery positive and the other wire should flash while cranking. that's the ECM controlling the injector.
Jul 29, 2020 at 6:41 AM
DIDEE813
  • 5 POSTS
my injectors are not getting power.
Nov 11, 2020 at 12:19 AM
DIDEE813
  • 5 POSTS
where is the crankshaft angle sensor located on Toyota pickup?
Nov 17, 2020 at 2:17 AM
4DRTOM
  • 467 POSTS
Your crank position sensor should be located on the front of the motor behind the timing cover. You should see two small wire leading down behind the harmonic balancer on the front of the motor. i have attached diagram of your ignition system hopefully it will help you out.
Tom
Nov 19, 2020 at 3:47 PM
