truck will not shift into drive
120,000 MILES • AUTOMATIC
LAWRENCE WATKINS2
I replaced oil pan gasket now truck will reverse and neutral but no drive.
Jun 12, 2017 at 1:21 AM
STEVE W.
  • 15,390 POSTS
Check the connector on the transmission and the wiring to it for damage/pinched areas. Also check the pins inside for corrosion. Double check that the block grounds are good as well.
Jun 13, 2017 at 1:38 PM
