Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
GMC
Suburban
Engine
Symptoms
Not Cranking Over
The engine will not crank just click?
1999 GMC SUBURBAN
249,000 MILES • V8 • 2WD • AUTOMATIC
AMY KRAMARSIC
MEMBER
1 POST
Charged the battery with a battery charger it shows it has full charge but, still it won't crank just clicks?
Jul 11, 2023 at 4:33 PM
BORIS K
Experienced Mechanic
A fully charged battery does not mean that the battery is able to carry a load such as cranking an engine.
The best way to test battery condition is to load test it:
A good video:
https://youtu.be/oHTbC73FAgU
Also check that the battery terminals are clean and tight:
Cheers, Boris
Jul 11, 2023 at 6:26 PM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
