Truck will not crank
167 MILES • 5.4L • V8 • AUTOMATIC
TMCCLENDON
I never had any issues with it cranking/turning over, one day I was about to go somewhere and all of a sudden it would not crank. all I heard was a click when I turned the key. the click sounded like it was coming from the starter solenoid, so I had the starter solenoid replaced. I had the starter replaced, and I had the crankshaft position sensor replaced, and it still will not crank. light and everything comes on. just will not crank. Could it be something electrical? What could it be?
Aug 22, 2019 at 11:31 AM
  • 110,248 POSTS
Welcome to 2CarPros.
Is the starter now engaging or is that still the issue? Have the battery terminals been cleaned and tightened as well as the main ground to the engine block?
If the starter won't engage, then we need to confirm there is power to the S terminal on the starter solenoid. Follow the directions in this link and let me know what you find.
If the starter is working but the engine won't start, take a look through this link:
If you haven't already, check fuse 21 in the fuse / relay panel. Also, pay attention if the gear indicator on the dash is working. If it is, see if it will start in neutral.
I attached a few pics. The first one is the starting system schematic. The second shows where the starter relay is located. Pics three and four are the fuse I am referring to.
Here is a link that explains how to check a relay:
Here are links that explain how to check fuses and I also added a few links which explain how to use the test equipment needed:
Aug 23, 2019 at 2:15 PM
JIS001
  • 3,412 POSTS
Hello and welcome to 2CarPros. I understand you replace the starter motor and still clicks? First thing you need to check is your battery. If battery is good, verify the cables are clean and free of corrosion. Also I need you to measure the voltage at the big red wire at the starter. You need to have battery voltage. If low voltage or none then there is an issue somewhere in that battery cable.
If you have battery voltage at the cable with an assistant, remove the trigger wire at the solenoid and with a volt meter check for battery voltage when the assistant turns the key to the crank position on the key. If battery voltage is present then check your ground cable as well. If you have high resistance at the ground it will cause a starting issue. If all is good then try turning the engine over by hand to verify the engine has not seized.
Here is a link on starter operation:
https://www.2carpros.com/articles/how-a-starter-and-solenoid-works
Here is link on volt meter usage:
And another link on how electrical systems work:
https://www.2carpros.com/articles/how-a-car-electrical-system-works
Let us know the voltage measurements and we can proceed from there.
Aug 23, 2019 at 2:21 PM
