Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Ford
Expedition
Interior
Dashboard
Replace/Remove
The truck went into a theft lock mode and had flashing lockout code on dash cluster?
2013 FORD EXPEDITION
187,880 MILES • 5.4L • V8 • 2WD • AUTOMATIC
DEANPOE
MEMBER
1 POST
I only have one key. Ran fine until i washed it about 2 months ago I pulled dash to change A/C evap coil.
Aug 7, 2024 at 12:50 AM
Experienced Mechanic
So this can cause a procedural error for the security system. I would try a reset process.
Here is a guide to help reset the system:
https://www.2carpros.com/articles/step-by-step-guide-performing-a-hard-system-reboot-for-your-vehicles-electronics-systems
If this doesn't work let's run the codes with a CAN scanner. You can get a CAN scanner (Controller Area Network) which will work on most cars from Amazon.
Here is a video to show you how:
https://youtu.be/u-4syLc-ifQ
Please go over these guides and get back to us.
Aug 7, 2024 at 10:26 AM
🔧 Tools & Auto Repair Parts
Shop on Amazon →
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
