Engine cranks but does not start
200,000 MILES • 5.2L • V8 • 2WD • AUTOMATIC
CARLOSWOODS
No power to coil, and the fuel pump not kicking on. The truck ran great until my lady backed into a telephone pole impact was rear bumper right on driver side frame.
Jun 16, 2022 at 3:36 AM
  • 110,251 POSTS
This vehicle has an automatic shutdown which is designed to shut down fuel and ignition if the vehicle is in an accident. I don't know how hard it hit the pole, but that is where I would start.
I attached a pic below and highlighted a fuse to check and the ASD relay. Confirm the fuse is good first. (Fuse 6) Also, confirm there is power to and from it. Here is a link you may find helpful.
If the fuse checks good and has power, remove the relay and switch it to a different one in the box that has the same part number. If there isn't one, here is a link that explains how to test one:
Let me know what you find.
See pic below.
Jun 16, 2022 at 3:51 PM
