truck stuck in park when running
165 MILES
BUDDYSR1000
I have a 2002 super duty 4x4 reg. cab. when running I can't get it out of park . I have to turn key 1 click put in nutral then start in order to be able too drive it. I replaced the nutral safety switch but that didn't fix it any feed back would be appreciated thank you.
Nov 10, 2013 at 8:47 AM
HMAC300
  • 48,601 POSTS
you have to have your foot on the brake so the shift lock will release. check fuses underhood and then have a pro check the shift interlock
Nov 10, 2013 at 11:08 PM
MAXIMILIAM
  • 436 POSTS
Thanks but I can't find your info. On your link could you please post it or send it again or give me info. On how to find it thanks again.
Buddysr1000
Nov 13, 2013 at 3:55 PM
