When we are driving the truck will stall. After sitting for a little while it will start back up and drive for an unknown amount of time and stall again, usually every ten minutes or so, but it seems to be getting progressively worse. We have changed: plugs, coil packs, injectors, fuel pump, fuel pump relay under the hood. Any ideas as to what could be causing this? Thank you.
Oct 24, 2017 at 12:29 AM
