engine temperature starts to go up it will gradually start to stall?
135,000 MILES • 5.2L • V8 • 2WD • AUTOMATIC
JROY13
So oddly enough my truck will start up cold and run perfectly fine but as soon as the engine temperature starts to go up it will gradually start to stall. Once i shift into reverse when its warm it will just stall out. Will also stall when i am slowing down which is super unsafe. It basically doesn't want to idle properly unless the engine is cold. The only thing i recently did was change out a power steering hose and the battery was disconnected. Any help is appreciated.
Nov 6, 2019 at 11:21 AM
MASTERWRENCH
  • 258 POSTS
Did the engine have this issue prior to disconnecting the battery?
Nov 9, 2019 at 12:23 PM
JROY13
It did not.
Nov 12, 2019 at 9:35 AM
CARADIODOC
  • 34,414 POSTS
I just answered this in another post a few days ago. Go out and drive the truck at highway speed with the engine warmed up, then coast for at least seven seconds without touching the pedals. In the unlikely event this doesn't solve the problem, do that again while holding the brake pedal up with your foot. Coasting meets the requirements for "minimum throttle" to be relearned after the battery cable was disconnected, but if the brake light switch is slightly out-of-adjustment, the brake pedal could vibrate, turning on the part of the brake light switch that cancels the relearn.
There can be other causes of low idle speed, but this is the only one that is caused by removing power from the Engine Computer. It happens on every Chrysler product, and is so common, most mechanics either perform a short test-drive for their customers or they inform them of the need to do this simple procedure. If you don't do it, you'll waste hundreds of dollars on unneeded parts, and still never solve the low idle speed.
Nov 12, 2019 at 9:49 AM
JROY13
I am getting a code now for the crankshaft position sensor.. codes are p0320 and p1391. Truck still runs fine when cold but when warm it acts up real bad now. Rpm's are jumping all over the place. Kinda surprised i made it home. I had to two foot the truck the whole way home. Pretty scary when you need to do a 3 point turn on a county road with the truck stalling.
Nov 28, 2019 at 8:15 AM
These codes are similar and are most likely causing your issue. I attached the code detail for the P0320 because I am sure that test will help you find the issue. The other code is for intermittent loss of cam or crank. If you fix the P0320, then I am sure you will fix the P1391.
Dec 1, 2019 at 9:49 AM
