Truck stalls, ABS light and emergency brake light flashes
139,117 MILES • 5.3L • V8 • 4WD • AUTOMATIC
ANTHONY HODGE2
My SUV has been acting weird. first the car sometimes is hard to cut on if it’s been sitting then every time I start to drive it the traction light ABS and emergency brake lights will flash and the car will stall. I’ll have to pump the gas to get it to go. I’ve had a new fuel pump installed, new battery, even cleaned a couple ground wires. but no luck. my gas gauge seems not to work.
Also I saw I little black wire hanging near back of engine. I grounded that with speaker wire and my instrumental cluster started to work again. it wouldn't cut on at first but it's still stalling and all those lights are coming on. am I using the wrong type of wire or something?
Sep 14, 2019 at 9:23 AM
