Truck stalled while driving, now will not start
177,376 MILES • 4.0L • 6 CYL • 2WD • AUTOMATIC
RES07G4M
My son was driving my truck he said it just stalled. parts I replaced: fuel pump, PCM, crank sensor,plugs, battery, check out the timing chain okay. getting fuel pressure okay. compressing okay. getting spark to the plugs. will not even back fire, spray starting fluid in it noting. in the beginning it did have a engine code crank sensor so i replaced that, but it still won't start. it a 4.0 litter OHV engine. transmission was rebuild two years age. any help I'm at my wit's end!
Apr 16, 2019 at 3:11 AM
Good afternoon,
Did you verify spark? Check for spark to the plugs.
Are there any codes stored?
https://www.2carpros.com/articles/engine-stalls
What was the compression?
Mar 2, 2021 at 4:12 AM
BMDOUBLE
  • 1,139 POSTS
Any codes stored? On demand test codes? If the base engine compression and timing is good, verify all the grounds are good also. Use a jumper cable and go from the battery negative to the frame and also verify that the ground on the firewall at the PCM is good and clean.
RES07G4M
good ground.
Did you check the compression and check for spark?
You need to check basics first before going to another area.
