I've gone through all of the grounds, and even ran new grounds to throttle control module. The truck ran good for about 2 hours, then it shut down again. When it shuts down, it will not turn off with the key. new ignition parts. turn the key off, open door and wait till it chokes out. The truck would run great after I cleared the code. Sometimes it would run for a few seconds and others it would go for 5 minutes, before the throttle would stop working. ECM has been reprogrammed. All I get for answers is to just change all electronic control modules. TCM and BCM are each 200 to reprogram, after purchase.
Jul 27, 2023 at 5:52 AM
