Truck really bouncy after leveling kit
67,895 MILES • 5.4L • V8 • 2WD • AUTOMATIC
JAEDAV12
  • 46 POSTS
I just installed a 3 inch leveling kit in the front in and went to take it for a test drive and it’s extremely bouncy. It’s never been like that before. Do I need longer shocks or is my alignment just that bad off?
Mar 6, 2020 at 1:38 PM
  • 110,248 POSTS
Three inches is quite a bit. It will certainly change alignment specs, so that needs done, but I don't see how that would cause it to bounce more.
As far as the lift, what kind was installed? The coils and shocks won't reach an additional 3 inches, I'm I a bit confused.
Mar 6, 2020 at 2:19 PM
JAEDAV12
  • 46 POSTS
It’s a coil spring spacer. You know the one the one that sits on top of the spring?
Mar 7, 2020 at 9:29 AM
  • 110,248 POSTS
Yep, very familiar. That saves you needing a longer spring and shock.
When you describe it as bouncy, and this is going to make me sound like a fool, but do you mean it wants to continue bouncing up and down (like a blown shock)? Or are you experiencing a stability issue?
I suspect the tire size has been changed as well. Are they properly inflated?
Here are the directions for checking the shocks right from Alldata. Let me know if it helps.
_________________________________
1998 Ford Truck Expedition 2WD V8-5.4L SOHC VIN L
Shock Absorber
Vehicle Steering and Suspension Suspension Suspension Strut / Shock Absorber Testing and Inspection Initial Inspection and Diagnostic Overview Shock Absorber
SHOCK ABSORBER
CAUTION: The low pressure gas shock absorbers are charged with nitrogen gas to 931 kPa (135 psi) for 1-3/16 inch bore, and 1034 kPa (150 psi) for 1-3/8 inch bore. Do not attempt to open, puncture, or apply heat to the shock absorbers.
All vehicles are equipped with low pressure gas-filled hydraulic shock absorbers of the direct acting type. They are non-adjustable and non-refillable. They cannot be serviced as cartridges and must be serviced as shock assemblies.
Before replacing a shock absorber, check the action of the shock absorbers as follows.
1. Check all tires for proper inflation pressure.
2. Check tire condition to confirm proper front end alignment, tire balance and overall tire condition such as separation or bulges.
3. Check the vehicle for optional suspension equipment such as heavy-duty handling or trailer tow suspensions. These suspensions will have a firmer feeling ride than standard suspensions.
4. Check the vehicle attitude for evidence of possible overload or sagging.
Many times, front springs and front shock absorbers are replaced in an effort to solve a vehicle sag concern. Shock absorbers are, by design, hydraulic damping units only and unlike suspension springs, do not support any suspension loads. Therefore, replacing a shock absorber will not correct a vehicle sag concern.
5. Road test the vehicle to confirm the customer concern.
6. Make sure the shock absorber is securely and properly installed.
7. Check the shock absorber insulators for damage and wear.
Replace any worn or damaged insulators and tighten attachments to the specified torque (on a shock absorber which incorporates internal insulators, replace the shock absorbers).
10. Inspect the shock absorber for evidence of fluid leakage. Leakage is a condition in which the entire shock body is covered with oil, and the oil will drip from the shock onto the pavement.
A light film of oil (weepage) on the upper portion of the front shock absorber is permissible and is a result of proper shock lubrication. Weepage is a condition in which a thin film of oil may be deposited on the shock outer tube (body) and is normally noticed due to the collection of dust in this area. Front shock absorbers which exhibit this weepage condition are functional units and should not be replaced.
11. If leakage exists:
- Make sure the fluid observed is not from sources other than the front shock absorber.
- Replace the worn or damaged front shock absorber.
12. Disconnect the lower end of the shock absorber.
13. Extend and compress the shock absorber as fast as possible, using as much travel as possible. Action should become smooth and uniform throughout each stroke.
- Higher resistance on extension than on compression is a normal condition.
- Faint swish noises are also normal.
Keep in mind, the vehicle is handling differently now because of the lift. Also, if you have put bigger tires on it, that may also be a cause or at least making a weak shock more noticeable.
Mar 7, 2020 at 12:21 PM
JAEDAV12
  • 46 POSTS
It's like the vehicle wants to keep bouncing up and down. Even going over bumps slow it bounces more than normal, it’s so bad it causes you to hit the gas sometimes harder than you want to. But I’ve checked the tire pressure and they’re all to spec and it’s in need of a front end alignment so I’ll get that done and see if anything changes.
Mar 8, 2020 at 1:42 AM
JAEDAV12
  • 46 POSTS
Also the tires were a set of 33x12.5R20 before the lift and still are.
Mar 8, 2020 at 1:48 AM
  • 110,248 POSTS
Chances are an alignment isn't going to correct this issue. I have a feeling it is a carry over issue that has become more pronounced since the lift. I would replace the shocks with something that HD. I have a feeling that will remedy the issue.
Don't laugh, but if you could video yourself bouncing the front of the truck and letting it settle, it may help me. Other than that, it sounds like the shocks are simply worn out. I'm not saying an alignment won't make it handle better, but if you hare hitting the throttle because it is bouncing too much, that's really bad.
Mar 8, 2020 at 1:10 PM
JAEDAV12
  • 46 POSTS
Thanks I’ll try it go with factory length shocks or something a little longer ?
Mar 8, 2020 at 1:45 PM
JAEDAV12
  • 46 POSTS
Also aired the tires to the recommended psi and it made it a little better.
  • 110,248 POSTS
Tire pressure can play a role. However, based on what you described, it's really bad. Be careful. Also, remove one of the shocks and see how much resistance there is when by hand you push it in and out.
Let me know what you find.
Mar 8, 2020 at 2:00 PM
JAEDAV12
  • 46 POSTS
Will do !
Mar 8, 2020 at 2:32 PM
