Engine stutters when decelerating
95,000 MILES • 5.9L • 3 CYL • 2WD • AUTOMATIC
ELIJAH RUDAT
First 15 minutes driving home was fine, no issues. Came to a turn and slowed down then the truck (auto trans) started to stutter. She was having trouble keeping up with switching gears, then stopped at a red light (still stuttering while slowing down), when the light turned green i gave her gas and she stalled out. Emergency brake light was off the whole trip but when i started her back up the light blinked on. I pulled the E-brake release and it was only pressed about 1/4 down., barely applied. After i pulled the release she has been driving normal with no issues so far its only been a couple hours. Is this a transmission issue?
May 23, 2020 at 11:01 AM
  • 110,248 POSTS
I don't think it's a transmission issue or related to the parking brake. Is the check engine light on and staying on when the engine is running? If there was an engine misfire, the light should be on. Also, weak fuel pressure can cause what you described as well.
If the check engine light is staying on, here is a quick video showing how to scan the computer to retrieve diagnostic trouble codes.
https://youtu.be/YV3TRZwer8k
I realize most people don't own a scanner, but often times, a parts store will do it free of charge.
If the light isn't on, let me know.
Take care, and congrats on graduating!!! Nice pic.
May 23, 2020 at 2:58 PM
ELIJAH RUDAT
Hey Joe, there is not a check engine light on. How do I check/fuel pressure?
May 23, 2020 at 3:01 PM
  • 110,248 POSTS
Here is a link that explains in general how it's done:
Here are the directions specific to your vehicle. They include the manufacturer's specs. You will need a fuel pressure gauge. However, most parts stores will lend or rent one to you. The attached pic correlates with the directions.
________________________________
1999 Dodge or Ram Truck RAM 1500 Truck 4WD V8-5.9L VIN Z LDC
Fuel Pressure Test - With Test Port
Vehicle Powertrain Management Fuel Delivery and Air Induction Fuel Pump Fuel Pressure Testing and Inspection Component Tests and General Diagnostics Fuel Pressure Test - With Test Port
FUEL PRESSURE TEST - WITH TEST PORT
Use this test in conjunction with the Fuel Pump Capacity Test, Fuel Pressure Leak Down Test and Fuel Pump Amperage Test found elsewhere.
Check Valve Operation: The electric fuel pump outlet contains a one-way check valve to prevent fuel flow back into the tank and to maintain fuel supply line pressure (engine warm) when pump is not operational. It is also used to keep the fuel supply line full of gasoline when pump is not operational. After the vehicle has cooled down, fuel pressure may drop to 0 psi (cold fluid contracts), but liquid gasoline will remain in fuel supply line between the check valve and fuel injectors. Fuel pressure that has dropped to 0 psi on a cooled down vehicle (engine off) is a normal condition. When the electric fuel pump is activated, fuel pressure should immediately (1-2 seconds) rise to specification.
All fuel systems are equipped with a fuel tank module mounted, combination fuel filter/fuel pressure regulator. The fuel pressure regulator is not controlled by engine vacuum.
WARNING: THE FUEL SYSTEM IS UNDER CONSTANT FUEL PRESSURE EVEN WITH THE ENGINE OFF. BEFORE DISCONNECTING FUEL LINE AT FUEL RAIL, THIS PRESSURE MUST BE RELEASED. REFER TO THE FUEL SYSTEM PRESSURE RELEASE PROCEDURE.
Fuel Pressure Test Gauge (Typical Gauge Installation At Test Port)
Pic 1
1. Remove protective cap at fuel rail test port. Connect the 0-414 kPa (0-60 psi) fuel pressure gauge (from gauge set 5069) to test port pressure fitting on fuel rail.
2. Start and warm engine and note pressure gauge reading. Fuel pressure should be 339 kPa ± 34 kPa (49.2 psi ± 5 psi) at idle.
3. If engine runs, but pressure is below 44.2 psi, check for a kinked fuel supply line somewhere between fuel rail and fuel pump module. If line is not kinked, but specifications for either the Fuel Pump Capacity, Fuel Pump Amperage or Fuel Pressure Leak Down Tests were not met, replace fuel pump module assembly. Refer to Fuel Pump Module Removal/Installation.
4. If operating pressure is above 54.2 psi, electric fuel pump is OK, but fuel pressure regulator is defective. Replace fuel filter/fuel pressure regulator. Refer to Fuel Filter/Fuel Pressure Regulator Removal/Installation for more information.
May 23, 2020 at 3:49 PM
