when I throw it into drive or reverse it goes silent
199,000 MILES • 2WD • AUTOMATIC
THESTRIKERDUEL1
so i turn the key over and the truck starts no problem, then when i throw it into drive or reverse it goes silent and will not move or anything. then i have to turn the truck on an off a few times. is it a clogged filter?
Apr 7, 2021 at 8:28 AM
  • 110,248 POSTS
Does the transmission eventually work? Have you checked for diagnostic trouble codes? What condition is the transmission fluid and is it full?
Do me a favor, see if there are any diagnostic trouble codes stored. Here is a link that shows how it's done:
https://www.2carpros.com/articles/ford-lincoln-mercury-obd1-1995-and-earlier-diagnostic-trouble-code-definition-and-retrieval
Let me know what you find.
May 4, 2021 at 2:39 AM
THESTRIKERDUEL1
my grandfather let me know i was overheating it by leaving the air on too long. i didn't know that was possible.
  • 110,248 POSTS
If you allow the engine run at idle with the A/C on, it is possible. However, it shouldn't happen.
Regardless, let me know if you run into trouble or have any other questions.
