Truck not starting
178,768 MILES • 0.7L • 5 CYL • 4WD • AUTOMATIC
TIFFANY KALUA
Truck turns on but won't turn over. Replaced fuel pump, then it drove fine. Replaced ICM, coil, distributor cap and rotor.
Feb 11, 2022 at 8:20 AM
  • 110,251 POSTS
Tiffany,
Welcome. I need to know if the starter is engaging and the engine not starting or if the starter doesn't engage.
Let me know so I know which direction to go.
Feb 11, 2022 at 8:27 AM
TIFFANY KALUA
Yes, the starter does engage. Only issue I am running into, is no spark to the coil.
Mar 16, 2022 at 11:23 PM
  • 110,251 POSTS
Tiffany,
If you aren't getting spark to the spark plugs, chances are it is related to the crankshaft position sensor. If you have a tachometer in the truck, crank the engine and see if the gauge moves a little. If you have a live data scan tool, check for an RPM signal when cranking the engine. If there isn't one, the sensor is my first suspect.
Take a look through this link and let me know if it seems to mirror what you experience.
If it does, that is where I would start. Here is a link that explains how one is replaced:
If you look at the directions below, they are the directions specific to your vehicle.
Mar 17, 2022 at 7:42 AM
