Truck losing power
250,000 MILES • 5.8L • V8 • 2WD • AUTOMATIC
PHOENICIA BRAZIER
SUV started to lose power when i drive and sometimes it doesn't want to accelerate and now its blowing white smoke and smells like something is burning. so, is the engine burning?
May 24, 2022 at 1:16 PM
SQM
  • 6,383 POSTS
One of the most common causes for low power output or limp mode is having a dirty throttle actuator. Dirt and debris can impact the effectiveness of the throttle position and other sensors and that can trigger the limp mode.
Cleaning out the throttle body can improve drivability.
As for the white smoke, does the vehicle overheat?
Typically, white smoke is due to a blown head gasket. In which the coolant will mix with oil and create smoke. Also, this will turn the oil to a milky white color.
Here is a helpful guide on how to test for blow head gasket:
Let me know of any questions.
May 24, 2022 at 2:28 PM
PHOENICIA BRAZIER
The truck is not overheating, the oil is not milky. i got a tune up and also a fuel pump because i thought someone put something in my tank. i also used some sea foam, they said a code on 3 and 7 misfire. i got the coils and injectors replaced and it seem like it has gotten worse.
May 24, 2022 at 2:48 PM
SQM
  • 6,383 POSTS
Inspect the throttle actuator and clean it out, if you haven't already.
Does the running issue only happen after the truck warms up or all the time?
May 24, 2022 at 3:48 PM
PHOENICIA BRAZIER
When i start it up sometimes i have to give it gas so it doesn't cut off then it runs okay. Then after it warms it sometimes won't accelerate, i have to let off the gas then it will run or try to idle down. it just started smoking a few days ago and it smells like i was burning rubber.
May 24, 2022 at 3:56 PM
SQM
  • 6,383 POSTS
Is your check engine light illuminated? If so, do you know what code(s) it might be producing?
May 24, 2022 at 4:07 PM
PHOENICIA BRAZIER
The check engine light had been on for a while, and it was steady on, but not flashing. i cant recall the codes, but i will go up to AutoZone tomorrow and have them print them for me and i can let you know.
May 24, 2022 at 4:16 PM
SQM
  • 6,383 POSTS
Sounds good. I want to see if that might give us a hint.
May 25, 2022 at 8:56 AM
