TRUCK LOOSES GAS PRESSURE WHEN I STEP ON GAS(BOGGING OUT)
177,000 MILES
MR2NDII
  • 5 POSTS
RECENTLY I BOUGHT A 2000 EXCURSION. TOOK IT TO THE CAR WASH AND I NOTICED WATER LEAKING IN THE CAB ON THE PASSENGER SIDE UP FRONT BY THE PASSENGER DOOR.RIGHT WHERE THE FUEL RELAY SWITCH IS.WHEN PULLED OUT THE PARKING LOT THE TRUCK DIED ON ME.THE FUEL PUMP WAS NOT WORKING.I GOT IT TOWED TO MY MECHANIC.HE HAS SINCE REPLACED MY FUEL PUMP AND FILTER.HE HAS CHECKED THE CRANK CENSOR,CAM CENSOR.HE MADE SURE ALL THE WIRING ON THE PASSENGER SIDE BEHIND THE PANEL IS DRY.HE CHECKED THE COILS AND THE MASS AIR FLOW CENSOR. THE TRUCK IDLES STRONG FOR HOURS BUT WHEN YOU GIVE IT GAS, IT LOOSES PRESSURE.LIKE SOMETHING IS KILLING THE PRESSURE.WHEN THE TRUCK DIES OUT IT STARTS RIGHT BACK UP STRONG AND RUNS STRONG FOR A FEW MINUTES THEN IT DIES BACK OUT AGAIN.
1.HE WOULD LIKE TO KNOW IF THE OXYGEN CENSORS WOULD CAUSE THIS.
2.WHAT AREAS TO LOOK IN NEXT.
3.WHERE IS THE FUEL INJECTION MODULE LOCATED
IT IS A 2000 V10 TRITON
May 15, 2013 at 8:47 AM
what is the fuel pressure idling and when this event happens??
1. no
2.back to fuel delivery
3.only with a diesel.
May 15, 2013 at 9:01 AM
MR2NDII
  • 5 POSTS
can you be a little more detailed with 2.back to fuel delivery..what other specific area need to be checked..THANKS
May 15, 2013 at 9:10 AM
MR2NDII
  • 5 POSTS
THE FUEL PRESSURE IS GOOD WHILE ITS IDLING. IT DOESN'T BOGG OUT UNTIL YOU GET ON THE GAS.IT EVEN HAS PRESSURE WHEN YOU START IT COLD BUT AFTER ABOUT A BLOCK IT DIES OUT.
May 15, 2013 at 9:18 AM
what is good??? what is the pressure??????
he is off base by going to other sensors now. he needs to be sure the fuel delivery system, fuel pump, is working correctly.
May 15, 2013 at 9:23 AM
MR2NDII
  • 5 POSTS
BETWEEN 39 43 POUNDS .IDLING.HE SAID THE HE PUT THE NEW PUMP ON AND THEN REPLACED THE FILTER WHICH WAS CLOGGED.HE SAID THAT IT GETS INSTANT PRESSURE WHEN YOU START IT BACK UP.SO IF THE NEW PUMP HAD BEEN BURNT OUT FROM THE CLOGGED FILTER THEN WOULD IT STILL GET CONSTANT PRESSURE WHILE IDLING?
May 15, 2013 at 9:32 AM
when he gives it gas, what happens to the fuel pressure???
roy
May 15, 2013 at 9:36 AM
MR2NDII
  • 5 POSTS
HES NOT SURE WHAT NUMBER IT DROPS TO WHEN HE STEPS ON THE GAS.BUT IT IS A SUBSTANTIAL LOSS AND THE TRUCK CHOKES OUT.
May 15, 2013 at 9:45 AM
thats your issue then. if he cannot figure this out, i would suggest another shop as he needs to be able to tell you the issue not ask for help.
could be the pressure regulator or the pump itself.
May 15, 2013 at 9:50 AM
