The engine is misfiring, is the fuel filter replaceable?
165,000 MILES • 2.5L • 2WD • AUTOMATIC
RANDY755678
Does the truck listed above have a replaceable fuel filter?
Jan 21, 2024 at 1:24 AM
BORIS K
  • 836 POSTS
If your vehicle has a petrol engine this vehicle has the fuel filter mounted inside the fuel tank, part of the pre-delivery pump.
If it is a diesel then the fuel filter is mounted under the truck, driver side.
A good video:
https://youtu.be/3KcP06MziBI?si=BjIHkKWIBRNNLUWm
Do you have engine light on?
If you do, then the vehicle would have set DTC.
Best would be to scan the vehicle for DTC and post them on our site for evaluation.
How to:
Some ideas to check:
Cheers, Boris
Jan 22, 2024 at 12:59 AM
