Truck is bucking
225,000 MILES • 5.7L • V8 • 4WD • AUTOMATIC
08STEPHEN52
After truck warms up, at light throttle or when i let off, the truck will buck hard one time, and then resume normally. This will happen every few miles. No codes in the computer. No sign of current interruption that i can find. I have re-manufactured the transmission, installed a new distributor, wires and plugs. Checked the coil, MAP, MAF and TPS. It runs better, but still bucks. Help
Dec 13, 2018 at 9:15 PM
Good morning,
It sounds like you may have a power interruption in the electrical system.
I would start by cleaning the battery cables to be sure there is no corrosion.
The ignition switch is another possibility as well.
Dec 13, 2018 at 10:00 PM
08STEPHEN52
Thanks. But I forgot to mention that new battery bolts, terminal cleaning and cleaning on the other end has been done and I have checked ignition switch for power interruption, without finding anything. Also, when I say the trans was re-manufactured, I'm talking about new solenoids, new internal wiring harness, new torque converter, everything. Very frustrated.
Dec 13, 2018 at 10:17 PM
Then I would check all your connections related to the ignition system for any corrosion or terminal damage.
Dec 13, 2018 at 10:26 PM
