Truck idles extremely rough and now strong smell of fuel
1998 FORD EXPLORER
267,000 MILES • 4.0L • V6 • AUTOMATIC
RACHEL VINCENT
After changing plugs and wires my truck is reading misfire in cylinder two and Incorrect ratio gear one, two, and four. Help! Also, I had been informed to gap plugs @ .054. Was this correct information? Thank you
Mar 14, 2017 at 1:52 PM
HMAC300
  • CAR REPAIR CONTRIBUTOR
  • 48,601 POSTS
it is supposed to e >052-,056". so you are in good shape I would send firing order and plug wire placement, but there are two different ones VIN numbers E or X. check that if it did not misfire prior. Otherwise scan it and take reading of sensors if you have one low or out of range that may be causing it as well as injectors.
Mar 14, 2017 at 3:47 PM
RACHEL VINCENT
My engine is an X vin
Mar 19, 2017 at 5:42 AM
HMAC300
  • 48,601 POSTS
see pics for coil/plug locations.
Mar 19, 2017 at 8:12 AM
RACHEL VINCENT
It needed a new coil!!! All fixed! Running beautifully!! Thank you for your help!
Mar 19, 2017 at 1:35 PM
