Hesitation when attempting to accelerate
321,000 MILES • 5.3L • V8 • 4WD • AUTOMATIC
MSNETTE03
When I start to drive and it's time to pick up speed, It starts to hesitate when I try to force it. It will not go pass 30 mph. It's scary at times.
Jun 27, 2020 at 6:45 PM
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
It sounds like you might have a weak or failing fuel pump and is not providing adequate pressure.First thing I suggest you do is test the fuel pressure.If you don't have access to a fuel pressure tester most auto parts stores have a tool loaner program and can rent you one.Here is a tutorial showing what is involved:
After performing this test get back to us with the results. I've attached a picture below of the fuel pressure specifications for your vehicle.Hope this helps and thanks for using 2CarPros.
Jun 27, 2020 at 8:29 PM
