Truck has good battery but no power
CORVETTEBILL
  • 2000 DODGE DAKOTA
  • 6 CYL
  • 154,000 MILES
When I turn the key I get nothing, no clicking or anything. When I turn it back to off there is a clicking that sounds like it is coming from behind the glove compartment. The lights do not work either but it has a good battery.
Sunday, February 11th, 2018 AT 6:10 PM
CARADIODOC
  • 33,956 POSTS
The clicking is a common symptom of a drained battery or bad cable connections. For the drained problem, follow the smaller battery positive wire to the under-hood fuse box, and be sure that connection is clean and tight. Follow the smaller battery negative wire to the body and be sure that connection is tight and not rusty. If we need to go further, we will need a voltmeter to take a series of voltage measurements.
Sunday, February 11th, 2018 AT 8:13 PM
CORVETTEBILL
Thank you for the advice. Is the clicking a common symptom even when the ignition is in the off position? When I turn the key to on there is nothing, only when I turn it back to off does it start clicking. I am working twelve hour night shifts this weekend so will not be able to do anything until Tuesday. I will get back to you with my progress. Thanks for answering.
Monday, February 12th, 2018 AT 1:44 AM
CARADIODOC
  • 33,956 POSTS
Yes. I read this quite often as a clue to low system voltage. Even though you turned some circuits off with the ignition switch, some computers need up to twenty minutes to go to "sleep" mode. Until that happens, they can be checking the fuel vapor recovery system for leaks, and running other self-tests. It is not uncommon for the system to draw three amps for that twenty minutes, and that is enough to cause low system voltage when there is a bad battery cable connection or a run-down battery. That smaller battery positive wire I mentioned handles most of the truck's current except for the starter. That is why given the multiple symptoms, that fuse box connection is a common problem on all car brands, and is related to both symptoms.
Monday, February 12th, 2018 AT 2:02 AM
CORVETTEBILL
Thank you so much. There was a problem with the battery cable. Not at the fuse box but at the other end. The clamp that attaches to the battery had an issue. Never the less, problem solved. 5 stars to you!
Saturday, February 17th, 2018 AT 7:05 AM
CARADIODOC
  • 33,956 POSTS
All right. One in a row! Happy to hear you solved it. Please come back to see us again.
Saturday, February 17th, 2018 AT 6:53 PM
