engine stopped running
150,000 MILES • 7.4L • V8 • 4WD • AUTOMATIC
CHARLIE BE
My truck started having a miss, then it stop running. this all happened after I got into some deep snow. A mechanic said he thinks I might have damaged a sending unit. Your thoughts please?
Feb 24, 2017 at 10:47 AM
CARADIODOC
  • 34,415 POSTS
A problem with a sensor circuit will be detected by the Engine Computer, and it will set a diagnostic fault code related to it. Having those codes read and recorded is the place to start.
Feb 24, 2017 at 10:55 AM
CHARLIE BE
Feb 24, 2017 at 11:06 AM
  • 55,766 POSTS
Hey CHARLIE,
This could be due to the fuel pump failing which is common on those trucks.
Please run this test and get back to us so we can continue helping you.
Best, Ken
Feb 27, 2017 at 2:09 AM
