When transmission is shifted into gear the engine shuts off
168,000 MILES
YBARRA210
Truck turns on and runs idle but as soon as it gets put into gear it shuts off. It will start right back up but as soon as it gets put into gear again it shuts off again. And it will stay turned on in park though.
Mar 4, 2021 at 10:23 PM
  • 110,248 POSTS
When you place it in gear, does the vehicle lunge? Also, is the check engine light staying on while the engine is running? Is the idle smooth when you have it in park?
What I suggest is this. This truck has a can-bus system. CAN stands for controller area network. Basically, all computer/modules are tied together via a few wires. By scanning the entire network, all codes will show regardless of the module involved. I suggesting this simply because it could be related to a few different things which involve different modules such as the TCM (transmission control module).
Here is a video showing how it's done:
https://youtu.be/InIlnsjOVFA
If you are unable to get a scanner that can scan the can, see if a parts store will lend you a basic scanner. At least we can check for engine codes.
Take care and God Bless,
Mar 5, 2021 at 1:16 PM
