truck dosnt roll very well out of gear
150,000 MILES
HARLAN29
After running a the truck for a while and stopping at a stop sign and getting it going again. It really drags like the breaks are on or something and when going down a hill out of gear it literally and slowly slows its self without breaking.
Jun 19, 2013 at 8:37 AM
FREEMBA
  • 1,152 POSTS
Is this a 4WD truck?
Raise the front wheels and turn each wheel by hand to see how freely they turn.
Do the same thing for the back wheels. If a brake is dragging you'll be sure to find it this way.
If it is 4Wd and the brakes aren't dragging; remove the front drive shaft and drive the vehicle to see if it now coasts downhill freely. If so, the problem is in the front differential/axle assembly.
Please post the result of your checks/tests.
Jun 19, 2013 at 9:47 AM
