Truck shuts off when we make right hand turn
156,000 MILES • 5.2L • V8
RKDILLY
When we drive the truck it will stall and shut off when we make a left turn. In slight right hand turns it will try and stall. Previous owner said fuel pump was changed. We changed ignition switch. This year does not have EGR valve. Any ideas?
Dec 26, 2019 at 2:20 PM
  • 110,248 POSTS
If you fill the fuel tank, does it still do it? If it still does it with a full tank, then it must be an electrical issue. Check things such as if there is a fuel pump fault code set, a loose fuel pump relay or fuse, the condition of the wiring at the fuel pump (at tank).
Have you done these things?
Dec 26, 2019 at 2:28 PM
RKDILLY
Does it with full tank and I hook my code reader up and no codes. I will look at relays tomorrow. Thank you
Rick
Dec 26, 2019 at 2:31 PM
  • 110,248 POSTS
If it does it with a full tank, then it's an electrical issue. Have you had the chance to check the things I mentioned? Also, have you checked wiring at the tank? Start the truck and move the wires around to see if you can cause it to stall.
Let me know
Dec 27, 2019 at 11:03 AM
