Truck stalls and then will not start
270,000 MILES • 5.0L • V8 • 2WD • AUTOMATIC
JESSE FONTENOT
  • 5 POSTS
Just picked this truck up at a whooping $600.00. It was running fine; now it tends to shut off frequently. I can start it and it will idle fine for five to ten maybe even fifteen minutes then just suddenly shuts off and I cannot get it started again. It will turn over but not crank. Maybe it is flooding itself out? today it started up fine but after driving it around the neighborhood for twenty minutes it shut off while driving. Smells rich when running. New spark plugs and wires. Any thoughts?
Aug 30, 2017 at 5:48 AM
  • 55,766 POSTS
When the engine does not start up does the ignition have spark? Here is a guide to help us get started:
Please let us know what you find.
Cheers, Ken
Aug 31, 2017 at 3:08 AM
JESSE FONTENOT
  • 5 POSTS
Yes it does. Someone told me today that it is the fuel selector valve.
Aug 31, 2017 at 8:28 AM
  • 55,766 POSTS
Yes I have seen that problem. does the truck have two tanks?
Aug 31, 2017 at 12:51 PM
JESSE FONTENOT
  • 5 POSTS
Yes it does
Sep 2, 2017 at 12:07 PM
  • 55,766 POSTS
Yep the selector valve caused big problems like you have described, I would replace the valve and see what happens, Ford has them in stock, (big surprise) it is located on the frame rial near the two tanks
Sep 4, 2017 at 7:03 AM
JESSE FONTENOT
  • 5 POSTS
I was having trouble locating it when looking so I decided to remove the bed...I am struggling with that due to one bolt. The one on the driver side that comes down next to the fuel lines is a real pain to get to. To top it off the nut has started to round off on me... any advice there?
Sep 6, 2017 at 2:22 PM
  • 55,766 POSTS
Can you take pic and upload them so I can see what you are talking about?
Sep 7, 2017 at 2:49 AM
JESSE FONTENOT
  • 5 POSTS
Sorry I didn't get back t you before. I ended up cutting the bolt out... but as it turns out the problem was the starter all along.
Now I have a missing transmission drain plug. Any idea on the specs of it or where I can find one?
Sep 26, 2017 at 12:16 PM
  • 55,766 POSTS
Nice work, we are here to help, please use 2CarPros anytime.
Please start a new question
Cheers, Ken
Sep 27, 2017 at 5:17 AM
