truck shuts off at random times when driving
120,000 MILES • 5.7L • V8 • 4WD • AUTOMATIC
DJSLANDSCAPING
Last week I was driving down the road and my truck shut off, was lucky enough to have it start right back up. Then it did it again and it took fifteen minutes of trying and it started back up. I got truck back home and put a spark tester on it to see the next time it died if it was a spark issue, and found that when it died next while it would not start it had no spark. Now truck had all ignition stuff replaced within the last six months. New coil, distributor(complete) and even new plugs and wires. I am at a loss of what to do next. So I hooked up a obd1 scanner and got four codes. dtc 13-o2 sensor error dtc 35 Idle air control error dtc 33 manifold absolute pressure sensor high, dtc 32 exhaust gas recirculation error. It also just got a brand new tank, fuel pump/sender, and new lines. Catalytic converter, and complete exhaust within last nine months. Please help!
Dec 30, 2016 at 12:11 PM
STEVE W.
  • 15,421 POSTS
DTC -13 - O2 sensor open circuit.
DTC -32 - EGR circuit error.
DTC -33 - MAP signal high.
DTC -35 - Idle Speed Error.
From those I would check the wiring harness where it runs along the head and exhaust and under the truck to the O2 sensor. All of these codes can be caused by a short to ground on the five volt reference voltage side or by an open ground. That would also explain it being random, it would only quit when the voltage is shorted.
Dec 30, 2016 at 5:24 PM
