Truck will not stay running
175,000 MILES • 5.2L • V8 • 2WD • AUTOMATIC
TOMMY SIMMONS
For some reason when I try to start my truck I have to give it gas. As soon as I let off the gas it shuts off. The fuel pump kicks on so I do not think it is that. Any ideas?
Nov 9, 2017 at 7:33 AM
  • 31,937 POSTS
Sounds as if the IACV idle air control valve has failed. this controls idle speed by bleeding idle air past the throttle valve. if the engine runs okay above an idle i would be suspecting this valve. it is located on the throttle body.
Nov 9, 2017 at 8:00 AM
STEVE W.
  • 15,423 POSTS
I would also check the throttle body for carbon build up. Very common for it to build up and block the air around the blades and the AIC also gets plugged. Usually a good cleaning does the trick.
This shows the general process.
https://www.youtube.com/watch?v=1PL1S1NNFFY
Nov 9, 2017 at 10:04 PM
TOMMY SIMMONS
I've cleaned the throttle body. I also swapped out the map sensor,iacv and tps. I still have a weird idle and it backfires every once in awhile now. Any ideas? Would my flowmasters be part of the problem?
Dec 12, 2017 at 2:59 AM
CARADIODOC
  • 34,416 POSTS
You're overlooking the most common cause of low idle. The battery was disconnected or run dead. Fuel trim numbers and other data will be relearned as soon as you start driving, but you have to meet a very specific set of conditions for "minimum throttle" to be relearned. Until that is done, you may have to hold the accelerator pedal down 1/4" for the engine to start and / or stay running, you won't get the nice idle flare-up to 1500 rpm at start-up, and it will tend to stall at stop signs.
To meet the conditions for the relearn to take place, drive at highway speed with the engine warmed up, then coast for at least seven seconds without touching the pedals.
Dec 12, 2017 at 8:32 AM
