Truck stalls
180,000 MILES • 2.8L • 6 CYL
ISAIASRDZ
When the truck is in idle it stalls on me, i also have problems shifting due to this problem. I changed the EGR Valve Control Switch, and the Temperature sensor'. What else can it be.
Thank you
Aug 31, 2017 at 4:26 AM
  • 55,740 POSTS
This sounds like you have a vacuum leak which can happen at the throttle body, here are two guides that will help you get the problem fixed.
and
https://www.2carpros.com/articles/stall-at-idle
Please let us know what happens so it will help others.
Cheers, Ken
Sep 4, 2017 at 4:57 AM
