Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
GMC
Sierra
Ignition
Spark Plug
Replace/Remove
Truck cuts out after replacing the spark plugs and oil?
2004 GMC SIERRA
317,217 MILES • 6.0L • V8 • 4WD • AUTOMATIC
RIVERNATIVE15
MEMBER
1 POST
I replaced the spark plugs and oil. Now it has a low idle and cut out when put into gear and press on the gas pedal.
Oct 8, 2022 at 1:08 PM
Experienced Mechanic
Check to make sure by accident you didn't disconnect any engine vacuum hoses.
Here is a link that explains how to locate them:
How low is the idle speed? Also, is the check engine light staying on when the engine is running? Do you feel any misfire (rough idle) when it is running?
Oct 9, 2022 at 10:25 AM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
