Truck got hot and shut off, will not start?
209,000 MILES • 2.2L • 4 CYL • 2WD • AUTOMATIC
MARTY158
The truck got hot and shut off, and would not start again, I put new spark plugs and wires, new crank sensor and cam sensor, and two new coil packs. It gets fuel to injectors and has spark still not starting.
Aug 15, 2023 at 4:37 AM
  • 55,688 POSTS
Will it run on starting fluid? Also, did you check the fuses? Can you please shoot a quick video with your phone so I can hear the engine cranking over? That way I can tell if the engine is okay. You can upload it here with your response.
In the meantime, please go over this guide:
https://www.2carpros.com/articles/car-not-running-advanced
I would check the compression to see if the engine is hurt:
Please go over these guides and get back to us.
Aug 15, 2023 at 4:42 AM
MARTY158
Will not run with starter fluid, and compression is good.
Aug 15, 2023 at 4:48 AM
  • 55,688 POSTS
Does it have spark? This video will help:
https://youtu.be/baq_aEWNQ0Y
Please go over this guide and get back to us.
Aug 16, 2023 at 4:00 AM
